Ladaklubi Foorum
Pole sisse logitud. [Logi sisse - Registreeri]
Mine lehekülje algusesse
Prinditav versioon
 Lehekülgi:  1  ..  6    8    10  ..  15
Autor: Pealkiri: Lada 2101 V6
Pöhö-Andrei
Registreerunud: 22.6.2007
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 3.1.2010 16:59
Thank you.
I look from tablebook weights for metalpipes and plates.
50x50x3 1.5mx4,25kg/m = 6,375 Kg
50x30x2 18mx2,31kg/m = 41,50 Kg
48,3x3,2 6mx3,56kg/m = 21,36Kg
3m^2 1.5mm = 35,1Kg
Total weight: =104,4Kg
Totalweight may gain about 20-30kg during this re-born process.
Ainoana suomessa Lada 2101 V6
Vaata kasutaja profiili Otsi kasutaja postitusi
robi
Avatar
Registreerunud: 10.9.2003
Kasutaja on eemal
Autod: 2107 1992
[*] postitati 3.1.2010 17:37
A lot less than I feared.
What do the rules and legislations say in Finland about rebuilding a car. In Estonia it is impossible to build a copy of your 2101 v6 as the engine can only be 20% bigger than the original put in the car.
I know of only one volga m21 cabrio built in Estonia which is road legal and the word was that they will not let registere cabrios any more without rollbars behind driver seats.
How about your car, will you be using a rollbar behind the seats or is the one incorporated with the windshield enough?
Vaata kasutaja profiili Külasta kasutaja kodulehte Otsi kasutaja postitusi Vaata kasutaja MSN Messengeri aadressi 5254672
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 3.1.2010 18:36
We can rebuild this kind of cars, so called "outsider of model-serie". In 2101-2107-serie belongs only 4-d sedan and combi so if i want build 2-d model, sedan, combi, pick-up or cabriolet i need exception permission from Vehicle Administration Centre (ajoneuvo hallintokeskus). This permission costs 340?. And i must do plan how i strength car body with calculations and drawings. In my case, having this permission takes nine (9) months.
About engine modifications: We have samekind of rules than you have but ...
New engine weight can be 20% bigger than original engine.
Effect in kW can be 20% bigger than original engine.
And volyme can be 25% bigger than original.
2101-2107 models are equal in this case, so we can use 2107 1.7i engine to fit referenses for new engine. For example Volvos 2.1 and Fords 2.0 ohc engines fits to this frames.
That rollbar question is exciting. In that exception permission i must give reasons for this rollbar and where i will install it. I get permission install it to frame of windshield. And this one rollbar is enough. I used 38% stronger pipe than rules said, so maybe that solved this thing.
Sometimes this rollbar must install behind frontseats, sometimes if rollbar is installed in frame of frontwindow, must install second rollbar behind backseats :P. It just never knows before this exception permission.
Interesting things and interprets.
[Muudetud: 3-1-2010 Pöhö-Andrei]
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 3.1.2010 20:33
Tsitaat:
Algselt postitas: Pöhö-Andrei
These modifications are free. But if for excample effect or weight is bigger than original +20% need excepetion permission and for engine it is difficult to get“.
But when under hood is Volvos 2.1L engine and all papers is okay, it is lawful put all tuningparts to engine, except turbo.
After inspection any main rule and law is 7kg/kW. So if ladas weight is 1100kg effort can be 1100kg/7kg/kW=157,14kW :P
And all that is lawful with out any changes for brakes or suspension. :o
Rocket with out brakes.
If you want install turbo to lada, then maxium horsepower is (lada2107 1,7i) 84hp*20%=100,8hp=74,11kW
Hmm, do i want turbo- or so called Old School- engine?
74,11kW vs 157,14kW
robi
Avatar
Kasutaja on eemal
Autod: 2107 1992
[*] postitati 3.1.2010 23:55
What about Konela turbo lada?
Sadly I could not find any acceleration figures or the power output exept what is mentioned in the article 32 sec 1km.
If it was a road legal version of Lada in Finland, then by the law it should be legal to add +20% power to the turbo version output, not the 84hp (regular engine).
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 4.1.2010 11:56
Tsitaat:
Algselt postitas: robi
Yes and no. This Konela-turbo is so-called "after market turbo" and it is impossible to use for comparison engine, (konela-turbos effot +20%).
If this turbo version would be made in Togliatti, and if it would be generally available in europe and in finland, it would be comparision model. Now it is not.
These turbo-ladas was not succes in Finland. Konela made only few cars with turbo. It was expensive and untrustworthy compared to normal lada.
Stockmann made also these aftermarket turbo-version, they used Ford Sierra 1.3 cars in this use. Effort 1.3 engine with turbo was about 100hp.
Interesting question is: Do you have any documents about lada with wankel-engine? It is made in Togliatti and available in russian and maybe in europe.
robi
Avatar
Kasutaja on eemal
Autod: 2107 1992
[*] postitati 4.1.2010 13:47
No more than what could be found by internet search engines.
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 17.1.2010 22:09
Last part is ready for paint-job.
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 17.1.2010 22:11
Ta-Daa... :D
apsu
Avatar
Registreerunud: 15.9.2008
Kasutaja on eemal
Autod: VAZ 2104
[*] postitati 17.1.2010 22:45
that's quite long :D
Vaata kasutaja profiili Külasta kasutaja kodulehte Otsi kasutaja postitusi Vaata kasutaja MSN Messengeri aadressi 53444609
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 1.2.2010 12:29
Image problem
I will try again later
[Muudetud: 1-2-2010 Pöhö-Andrei]
Avatar
Registreerunud: 19.4.2003
Kasutaja on eemal
Autod: 2101, 2103, Citroen C4 Picasso, ZAZ 968m, Izh 412ie, Yamaha Virago, Temsa Safari HD
[*] postitati 1.2.2010 15:35
Tsitaat:
Image problem
Attach image size is max 100 kb.
Try this http://imageshack.us/ and link image: [img]your image link[/img]
Balti ketis seistes, Lauluväljakul Eestit vabaks lauldes ei näinud meis keegi ka kõige hullemas unenäos sellist hävingut, töötust, vaesust ette....
edit: 09/2014 Tegelt pole häda midagi siin :P
Vaata kasutaja profiili Külasta kasutaja kodulehte Otsi kasutaja postitusi Vaata kasutaja MSN Messengeri aadressi 5076179
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 1.2.2010 23:05
Saturday's cartoon Savon Sanomat newspaper.
Hmm, looks familiar.
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 9.2.2010 20:25
A man and his hobby.
Published in the newspaper Savon Sanomat 9.2.2010.
http://www.savonsanomat.fi/teemat/autot/autotalli/lada-v6-saa-kohta...
karl01
Avatar
Registreerunud: 14.9.2009
Kasutaja on eemal
[*] postitati 9.2.2010 22:34
the hood looks looks like it came off from gaz 24, but it is nice! how far is the project?
Enamjaolt on ikkagi süüdi istme ja rooli vaheline tihend!
Vaata kasutaja profiili Otsi kasutaja postitusi Vaata kasutaja MSN Messengeri aadressi 56333412
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 9.2.2010 22:58
I try to paint the car's chassis and engine room during next weekend. I have three days off from work so I use it for that purpose.
karl01
Avatar
Kasutaja on eemal
[*] postitati 9.2.2010 23:02
and then lot's if pictures!:D
apsu
Avatar
Kasutaja on eemal
Autod: VAZ 2104
[*] postitati 10.2.2010 15:35
how much does this backing up light illuminate? Nice place for it :D
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 11.2.2010 22:25
Tsitaat:
Algselt postitas: apsu
Thank you.
It is old front fog-light, now H3 100W lights really well .
Must be nearly blind, if not can see to drive backwards. :D
[Muudetud: 11-2-2010 Pöhö-Andrei]
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 13.2.2010 18:14
Sanding sanding sanding....
And little bit viru valge. :D
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 14.2.2010 11:16
:D
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 14.2.2010 11:17
BRILLIANT...:o
karl01
Avatar
Kasutaja on eemal
[*] postitati 14.2.2010 14:43
niice:cool:
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 14.2.2010 14:53
Engineroom.
Pöhö-Andrei
Kasutaja on eemal
Autod: Lada 2101 V6
[*] postitati 14.2.2010 14:54
Not bad, not at all...
  Mine lehekülje lõppu
Powered by XMB
XMB Forum Software © 2001-2011 XMB Meeskond
[PHP: 38.9% - SQL: 61.1%]
